Shocker XLs
Propane air tank
100%duty 220psi compressor
150/110switch
Nice, got any videos?
Welcome to the forums.
Thanks I’ll have some this weekend.
Welcome.
If not a video then at least pics because I’m curious about the air compressor, its CFM @ 100 PSI, and its long term duty cycle.
^^ dc7600 ?
Let it be known that “100% duty cycle” is not the same as continuous duty.
I searched online, quite a bit, and all Chassis Tech compressor specs are very vague so beware.
It is a wnp400 I guess it’s a viair 380c copy it has on paper
Duty cycle100% @100psi
1.59cfm. 220max psi
I’m wondering if these shockers would be better mounted on the frame facing forward or keep them facing down
They will be loud regardless, facing them down will be loud everywhere around you, forward will still be loud and will travel farther.
Update
Hiding most of the wiring, wired in to stock horn and alarm. Its on it’s on switch so I won’t wake my neighbors up when I lock my jeep. Waiting on my switch panel so I can mount my switches. I have to make some kind of bracket to set my air compressor on my propane tank.
