have the above truck with club cab and can’t seem to find horn/s. did a search and didn’t get any hits, but i might have left out word or words…does anyone know location and what might have to be removed to get to em…got all the plumbing done and mounting and trying to work on electrical hook-up…stuck here trying to find splice location to wire into. (going the factory steering wheel push button route with switch to select which horn activates)…thanks in advance…
sorry if i wasn’t clear enough in the original… i wanted to know where the factory horns are located so i can splice into the wiring…
i have mine mounted already…had to make bracket and mount horns behind transfer case in front of gas tank…they are all above the skid plates. compressor is right close by on frame and tank on other side of frame on edge of truck. tank was challenge to get it high enough to get clearance for powersteps to still close, but they offer a bit of protection when tucked under. still have to run suction filter for comp. into cab under seat and finish wiring…here is photobucket links (all i could manage with pic restrictions)…
here is a pic a helpful fellow sent me from another forum i asked the same question on… you can see the 2 shiney factory horns right at the top under the plastic shroud with heavy duty on it…hope this might help someone else…
