SO, This is my first Horn Kit. I got a Shocker XL Kit but only with a 2 Gallon Tank to fit in my Truck. I have a new 2016 Toyota 4Runner and found that underneath and inside were impossible to get this thing mounted, but in front of the Radiator behind the Grill is plenty of room for all of it. So now that I have everything installed I need some help. I can fix mechanical things, take stuff apart and such, but I suck at electrical.
- I know it says you must mount the valve with the arrows going to the horns… well this valve had no arrows so hopefully its right.
- Not sure where to hook the system to the battery. DO i just pull a red wire near the battery? How do I know its going to the battery or is there a simpler way to power the thing.
- The instructions show the toggle wired to the horn on the steering wheel. How the hell do I know which wire to splice under the dash to hook it to the steering wheel horn?
Any help with the last bit of wiring and I can have it all wrapped up. Thanks for any help I can get!
