2020 Ford F350 - Conductors Special Train Horn Kit
Bobby J. brought serious sound to his 2020 Ford F350 with the Conductors Special Train Horn Kit, turning an already powerful truck into an absolute attention-grabber. The Conductors Special Train Horn Kit is a perfect match for heavy-duty builds like this F350, delivering that deep, authentic train horn blast that cuts through anything on the road.
For this setup, Bobby mounted the horns securely underneath the truck along the frame rail, keeping them protected while still allowing maximum sound projection. The onboard air system was installed cleanly with easy access for maintenance, making the entire setup both functional and reliable for everyday use.
The result? A clean install, factory-like integration, and a horn that means business. The Conductors Special Train Horn Kit continues to be a go-to choice for truck owners who want serious volume without compromising on install quality or durability.
If you’re running a heavy-duty truck like a 2020 F350, the Conductors Special Train Horn Kit is one of the best ways to upgrade your presence on and off the road.
#FordF350 #TrainHorn #HornBlasters #TruckBuild #DieselTrucks #TruckLife
#ConductorsSpecial #LoudAndProud #CustomTruck #AirHorn #BuiltNotBought
This is the best investment that money can buy! can’t wait to get one for my self and have fun with it!
Had the same one on my truck. It was freaking loud!
Wow! You can install them individually?
