2026 Dodge RAM 2500 - Stealth Spare Tire Delete Kit
Michael M. upgraded his 2026 Dodge RAM 2500 with the HornBlasters Stealth 5 Gallon Spare Tire Delete Kit , creating a clean, hidden onboard air setup by utilizing the spare tire location beneath the truck. The stealth mounting keeps everything tucked away while providing plenty of air capacity for train horns, air tools, and other pneumatic accessories.
To make the setup even more functional, Michael also added the HornBlasters Tire Inflation Kit for convenient tire inflation wherever the road leads, along with the HornBlasters Electric Drain Valve Kit to quickly remove moisture from the air tank with the push of a button. Together, these upgrades make the Stealth 5 Gallon Spare Tire Delete Kit an all-around solution for performance, convenience, and easy maintenance.
If you’re looking for a clean onboard air system for your heavy-duty truck, the HornBlasters Stealth 5 Gallon Spare Tire Delete Kit is built to maximize space without sacrificing performance.
#HornBlasters #Stealth5Gallon #SpareTireDeleteKit #RAM2500 #DodgeRAM2500 #2026RAM2500
#OnboardAir #TireInflationKit #ElectricDrainValveKit #TruckBuild #TruckMods #DieselTruck #AirSystem #TrainHorn #BuiltNotBought
