I have two different horns, and i wanted to be able to select which horn to blow. The solution was to make this configuration to allow me to blow the K5LA or the P3, or BOTH depending on the position of the switch. This switch is a “ON—Center off—ON” switch. This is used with a combination of inexpensive hornblasters solinoid valves.
It is actually quite simple.
I don’t understand why you have 4 valves for 2 horns.
Which connection points are in and out?
It’s cool - I’ll give you that. So do you always use the stock horn button or is there another momentary button as well?
ya, in addition to the stock horn button, i have a graham white valve pictured below.
two shifters too? damn u like to double up on everything huh lol
