viair recommends a tank size upto 5 gallons for their compressors. Has anyone used a tank larger then 5 gallons for one compressor? What happens if you use a tank larger then 5 gallons? If you use a check valve it shouldnt put strain on the compressor right?
Thanks
You void the warranty on the compressor if the compressor manufacturer finds out.
It also helps with refills times.
The only compressors out there that I know of that won’t have this problem are the Oasis and the Extreme Outback engine driven compressors, or a York 210 if you want to build one yourself. They’re made for that kind of abuse because they’re high volume and constant duty rated.
