I’m sealin the deal on one of these long awaited HB Train Horn kits at the end of this week!
Lookin to drop about $600 MAX… What should I get?
I originally wanted the Shocker 232, But now I got a bit more change and heard it’d be best with the 240 because of the 5G tank? Is that the only difference between the 2?
i will second that…k3la is a beast!! the price will hit your wallet at first…but once they are paid for and on…its amazing… i actually thought something was wrong with mine last night i said “no way this is suppose to be this loud”!! ha ha!!
I was kinda thinking about that route, but where could I get a k3, tank, compressor, all the airlines, pressure switch and everything else for $600! lol
Well, you need a 10-12ga wire from your battery to the relay - with a fuseholder.
you need ~18ga~ from your 'key-on source to the pressure switch.
you might want a toggle switch for a master compressor shutoff.
Airline & fittings are the question.
Would you use the Nathan manifold or the Aluminum brackets?
If you use the separate brackets, you’ll also need a splitter manifold like Curt S sells…and more fittings.
I think if you use the Nathan manifold, you could get everything else you need for the remaining $50 of your budget…lol
You know what - I forgot - you’ll need a 1/2" solenoid valve too. So add $49. Dang it!
Yea I was think bout buyin some sheet metal and bolted them on under the truck, but would also like to put them behid the grill cuz I got room… And no chance of getting stolen. I’m looking for the most sound, though I’m sure it will still scare people shitless reguardless lol.
