82 Chevy Pickup
548XL
Ok guys it’s finally done!
Thanks Rigo-Garrett-Matt and all the others at HB! Man i must say video does these shockers no justice!!!
Ok here’s what the Xl’s went on.
No spare anymore
For the tank
Viair compressor mounting bracket, thanks lance!
Making the mounting bracket for the horns
This is welded into the Viair mounting bracket
Getting the fit just right
Ok, almost 3 weeks later it’s all in!!!
The toggles turn the compressor on and off and the other turns the momentary switch on and off
The trigger is a momentary push button. Normally used for nitrous, trans brake, starting engine…etc etc…it’s made with a piece of 1/2 inch pvc and wrapped in the heat activated wire wrap.
Gotta rep for my team!!!
The End. Hope you guys enjoy! Thanks again everybody over at HB!!
Welcome! I think the will fit with no problems at all…
Thanks awesome site! i added one pic ill add more after my install…
i dont think the horns are gonna fit under the lip at the top of the bed. best place to put them would probably under the bed.
yeah, i think thats where they are going to end up. Also i currently have a Hadley air horn kit already in it. Should i use both? or the 548xl will be enough?
the XL will def. be enough. but if i was you id leave the other one too just for fun. i still have my small horns on and its still fun to honk them once and a while, and when people honk back, then i switch over to the big horns
cool, ill leave them on…
WElcome to the forums. like ur truck color
thx…
I’M FINALLY GETTING MY 548XL INSTALLED TODAY!!!:):):):):slight_smile: The guy who works on my truck was very busy so i had to wait. I wanted to get it done right!
take some pic’s of the install!!!
done.
awesome install! i love te gauge i want one!!!
Thanks man, it took long enough. I don’t think i could have waited much longer or i would have been under the truck myself.
Nice install dude! wots the difference between the 240XL’s and the 548xl’s?:confused:
Thanks Pete. The only difference is the tank size and compressor size. I think.
The tank and the compressor
240 = 2gal + 400C.
548 = 5gal + 480C.
Mate? Wots the black AZ thingeymebob?
sending unit/sensor for the digital gauge. I want one of those gauges too.:smiley:
