Adding train horn to air ride system
I currently have an AirLift suspension on my 2011 Mustang & I am wanting to add a train horn to it. I am hoping to use part of what I have already. I am using a 148lb tank with duel Viair pumps. I wont have trouble replenishing the air at all. I also use 2 water collectors with drain between the pumps and the tank. The tank have plenty of available port to use to run the air out.
Has anyone done a setup like this or know of one I can check out online?
Yes, I did try to use the search on here before asking this question.
You shouldn’t have any problems running a train horn off of that at all! :smiley: Just make sure you have either a 3/8 or 1/2 inch ports on the air tank. Also Might add if you purchased just the horn, you might want to consider either a manual valve or an electric Valve of your choice size. Unless the horn came with one then you are set. :slight_smile:
Welcome to the forum.
Yes indeedy, it will work perfectly:D
Don’t look at the PSI of the tank, but how much air it holds in gallons. I had a Firestone kit on my truck, and most of the AirLift kits will have a small tank … usually under 1 gallon.
This might be the only part you’ll need to replace, along with finding room for at least a 2 gallon tank using the Shockers or the Conductor’s Special.
Thanks for the replies guys. The AirLift kits uses a 5 gallon tank with 8 ports.
Any recommendations of what to go with? I have room behind my grille for mounting or a bit of room in engine compartment, but couldnt do a massive 5 horn set-up.
You’ve got some options …
You could do the Shocker XL horns, or you could do a K3LA and then get the manifold delete for it.
Really it depends, at this point, whether you want a real train horn or something that sounds just as good for a bit less in costs.
Wow!!! Car Porn…Nice:D
If I were you I’d go with the Shockers, they are lighter than any of the K series horns and can be mounted where ever they fit. :smiley:
Or do what Marine One said and get individual manifolds for super loud K3’s.
Welcome to the forum. Sweeeet Stang!
I second that… what an awesome ride. Love the rims.
I’ll also put in a another vote for the S4 Shockers (go the XL series with 1/2 feeder line and solenoid). Loud has hell and far more flexibility to get them mounted.
