I have the Conductor’s Special Model 540 and I want to put an air hook up. how should I go about this? like what exactly do i need to hook it up?(EX:fitting/hose/etc.)
PS: I want to be able to take the hose off(quick disconnect)
This depends on where you are putting it… So many options here.
Heres my setup
I have the quick connect right on tank. Also on the tank on right , the last port i have a elbow PTC fitting ready to install my aux quick connect…
I am going to run a line from there under truck back near hitch and mount a quick connect there so i can air up tires and such and have the quick connect on outside. I use to have a reel mounted in bed but installed the second tank because my k3 is air thirsty with the 5/8" OD line
Okay I’m going to do something like that. ill post pics of my new setup ASAP
