air line size
HI,
I cant locate any 1/2 barbed fittings here, so forced to go with 3/8" & 1/4" ones for my setup.
BUT the question I had was, the 6" of filter hose that came with my 480C, is that the same air line that they sell here? http://www.hornblasters.com/products/details.php?i=1-2-in-dot-air-line
I wont be using it for remote location of my filter so was curious if it could be used for the horn hoses.
Also, the ID is about 3/8". Is this all thats required for the 1/2 valves and horns like shockers? Or is there another larger size?
( The HB 1/2 line shows Outer Diameter 1/2 in, so inside would be about 3/8"? so I use 3/8 fittings for this?)
The 3/8 hose shows Outer Diameter 3/8 in Inner Diameter 1/4 in
So when referencing the 1/2 hose needed on some horns and valves, the outside is 1/2" and inside would be about 3/8"?
Thanks!
Jason
The tube for the air inlet is probably not pressure rated. It’s just a wimpy tube for drawing in air (suction).
The tubing Hornblasters sells is DOT tubing - measured by the OD. So yes the ID is smaller. IDK if 1/2" tube would work over a 3/8" barb. That hard tubing is not meant to stretch.
Barbs are usually meant for hose which is measured by the ID.
Perfect! Just wanted to make sure I am installing the right tubing so wont need to replace down the road when I get bigger horns or eventually get a k5la under her :wink:
Then you want 1/2" tubing (OD) minimum.
Some guys do 1/2" ID for an upgrade with the Nathans.
That would be 1/2" hose or 5/8" DOT tubing.
Thanks :slight_smile:
