Oooompa…dooompa…dippppity-dooo…I got a couple of questions for you;
Does a pressure regulator go in between the solenoid and the horn (or vice versa) or are they supposed to just regulate the overall pressure in the tank (the latter being useless to me if thats the case).???
Is there any truth to this; http://www.*************/v/techzone/Compressor_Install.pdf (under DO NOT)
And why would a 150/180 psi compressor not be able to fill a tank at 200psi???
Cheers.
