Air tank upgrade
Hi guys, ok been trying to find a definitive answer and going around in circles.
Righty, it’s been a while since i’ve been on Hornblasters (should come more often!) and as such see that the Shocker XL kit has changed from the one i bought about 2 or 3 years ago! Looks like the tank and trigger switches have changed from mine?
But with the current £ to $ exchange rate, i want to take the opportunity to do some upgrading, mainly to a bigger tank. I’ll confess, i’m confused with the ports and fitting things on the tanks.
Looking at the 5 gallon tanks for extra honking time, but which one is the one i need for my system?
IIRC this is my current tank:-
http://www.hornblasters.com/products/details.php?i=hornair-black-2g6p-air-tank
As it has two 1/2 ports, can i simply link it to this tank and still use everything else the same?
http://www.hornblasters.com/products/details.php?i=hornair-black-5g8p-air-tank
Sorry for being thick, want to get things right so dont blow myself up lmao!
Many thanks
Speedy
Do you have a spare 1/2" port on your current tank? You could easily connect it to a new tank. Just plug the rest of the ports and put a drain fitting in the bottom.
Your compressor is probably out of warranty anyway, but they’re really meant for up to 5 gallons. Who says it wouldn’t have a long, happy life filling up 7 gallons though? lol
Just connect the tanks with the same size airline & fittings that are used for the horns.
we have a 6 gallon tank similar to HB’s 5 gallon $79.95 - http://aircompressors.oasismfg.com/item/air-compressor-kits/air-storage-tanks/item-1109?
Ohhhhhh me likey sound of that!
Re spare 1/2 port, i don’t think i do tbh? This is pic of the tank as i was installing…
I think the spare port is 1/4 as according to the parts section on the main HB page, the pressure switch is 1/4 so i’m assuming the free one is the same.
Looks the best option i think, just to cover all bases of various ports. Does this come with the fittings to blank off spare ports, and how much for postage to UK?
Edit…
Ok been looking at the pic again (annoying as the car isnt here)
The lead from the compressor to the tank looks like its going to a reducer that was upplied with the kit. If i think im right, i can put the compresser without reducer directly in the port next to the pressure switch, and that will free up a 1/2 port?
Yessssir.
Or to free up that port, move the compressor & reducer to one of the new ports on the new tank.
Excellent, just what i wanted to hear! :slight_smile:
So getting new parts. Obviously the tank, what else will i need, do still have to have a drain valve, pressure release etc on the new tank… and most importantly, how do i link the two tanks?
I see a PTC on your existing tank for the horns. You need 2 of those and some airline.
You need a drain on each tank because water will collect in them both. Plug any unused ports. When complete, they are essentially one big tank…no need for additional safety valves.
Thanks ear2ear, much appreciated! Would i be able to get the brass blank plugs, push to connect and drain valve seperatly from?
Would Hornblasters be able to supply these?
Yes, but Stinkpete might know where to get them on your side of the pond. Might be cheaper…
Ah right ok, will send him a message first then :slight_smile:
The tank does not come with plugs for the ports. We have new 1/4" brass plugs ($1.40) and 3/4" steel plugs ($1.50) available. We also have unused steel plugs (70 cents each) for all 3 port sizes from new 10 gallon tanks that we build into complete systems.
Shipping by postal service:
Global Express Guaranteed® (GXG)**: 1 – 3 business days = $165.97
Express Mail® International: 3 – 5 business days = $111.49
Priority Mail® International: 6 – 10 business days = $104.75
Insurance and Tank plugs may raise shipping cost.
Hello Stu,
I do have a selection of brass fittings, I got drain cocks, 1/2" push fit for the pipe & blanks. Tell me exactly what you need and I will see what I can do :slight_smile:
Hiya guys, quick question…
What is the size of the air hose supplied in the kit that goes from the tank to the horn activator? I can’t remember…
Thanks!
Should be 1/2" O.D. tubing.
Thought as much, excellent, thanks!
I have ordered your tank mate :smiley:
