Have any of you guys had issues running more than 5gals per compressor with Air Zenith compressors? I’m currently working on a new install after buying my old K5 back, and I have 2 OB2 compressors feeding an 8.5gal tank. I have two 5gal air zenth tanks I have thought about adding to my setup though. Since these K5s really like a lot of air!!!
Consider upsizing to an engine driven compressor or an Oasis compressor. The more air you can put into the system in the same amount of time as your electric compressors … the less your need is for static storage.
That’s my recommendation … as opposed to exceeding the recommended specs for your electric compressor(s). Stupidly fast refills are nice. Once you go big (i.e. 8-10 CFM or better from a single compressor) you won’t ever want to go back.
I’ve one in my truck for this very reason. If you want more info on it just ask bro.
