but in aluminum instead of steel?
http://www.trainhornkits.net/air-lift-2-gallon-6-port-air-tank/
The mounting space on my Scion is kinda tight and I need a tank with a drain port on the top cause it will be mounted feet-up under the body…
I prefer aluminum over steel cause I live in the rust belt and I would usually just weld in a bung myself, but I don’t have access to my tig welder anymore as my new job is here in NYC and my shop is back in Orlando :rolleyes:
