I’m in Chicago and trying to sort out heat for a small unheated garage setup where I keep my compressor and do horn wiring and bench work. Space heaters trip the breaker, so I’m looking at a diesel air heater instead, specifically the VEVOR 8KW Bluetooth unit. I came across this page while searching: VEVOR 8KW Diesel Heater Review: Bluetooth Diesel Air Heater. What I’m unsure about is whether an 8KW rating is realistic or inflated on these import units, and how they behave on a thermostat cycle when it’s well below freezing outside. My bigger concern is exhaust routing in a garage with a door that isn’t sealed tightly, plus whether the Bluetooth control is useful or just a novelty. I don’t want to buy twice. If you run a diesel parking heater in a similar cold-weather setup, what actual heat output and fuel burn are you seeing, and how did you handle venting?
