Auxiliary switches
I installed my horn blasters 232 kit on my ford raptor this past weekend. I installed two toggle switches temporarily so that I can hopefully use my factory up lifter switches instead for a cleaner look. One switch toggles between stock horn only and both train/stock. The other cuts power to the compressor.
Any idea if the wiring would be different to hook them up to the up lifter switches?
If you search “upfitter” you’ll have better luck than up lifter. There are a few threads. Here’s one:
http://www.trainhornforums.com/showthread.php?t=5192&highlight=upfitter
