Is it possible to mount the shockers, tank, compressor, (2gal, 325c)and switch all in a backpack?
I’ve had some ideas, and earplugs are a must if possible.
Ive thought of this. If you had the tank full, and on a manual valve, you could do it without the compressor and or any electrical.
Why not keep it simple?
CO2 fire extinguisher, hose, horns.
Kris
^ still need a valve, unless your planning on using the valve from the fire extinguisher.
Use A little tank of nitrogen…
a remote mounted paintball tank… already has a mini regulator all u need is a valve
I’d love to see that!
Exactly my point … use the valve on the fire extinguisher, and it’s one less thing to carry and/or worry about.
There are several YouTube videos out there where they use this setup for quick testing and the video clips themselves.
Kris
Don’t forget the battery :D.
Where’s the vid Matt??
I just had an idea!
http://www.northerntool.com/images/product/images/155335_lg.jpg
if it can hold the pressure use the blow gun at the top, it would be just like a manual valve.
The draw back is the small air hose going from the tip to the horns. Would this work or am I overlooking something important?
not enough airflow.
I used the same thing to test my shockers at the garage and it was pathetic. lol
Same here. I can only do 1 Nathan bell at a time with my blow gun. Although that’s the small rubber cone tip.
I will work on that video tonight… I’m not having a hard time editing anymore, it’s exporting to the highest quality format thru final cut express that’s giving me a hard time… i need the Tiernan!
