Well had the k3 a while now. It just doesn’t seem to be loud enough. It’s under a sled deck, with about a 3" gap all the way around.
Is there anything in a reasonable size that’s louder? I was thinking a t-3 but it’s rating is lower, than my k-3la.
I can’t mount under the truck because it’s a work truck, and I’m offroad lots and in the mud, I don’t think it would like that. Above the truck doesn’t work. I need the rack to haul things, and theft would be a concern.
No, they are machined for flow. They are swagelok fitting I use in process at work. And the bends in the tube are gone with swagelok
Benders with rollers, so they don’t crush on the bend. Just curious. Perhaps a second k3. I’m getting 2 tanks built from 4" pipe for my truck, to total about 10gal. I’ll put dual comps, maybe a second horn is the way to go.
It also seems that with the tailgate down and a fairly clean line out its not as loud as beside the deck. Just how things bounce around back there. I find in the open I don’t get the echo I was looking for, unless trees are near by. Near buildings or tight areas it’s great. Mostly the big open areas and getting some echo off some trees 1/2k away etc.
