Anyone here using that valve? Would you recommend it?
Big difference in price compared to a graham white. I just need something that does the job. Not for frequent use.
Hi flex sorry can’t help but hopefully someone will be along soon to help you out
Have a look at this… HB was kind enough to write up a comparison a while back:
https://www.trainhornforums.com/showthread.php?t=6272
Thanks! I could not find that thread:D
Too bad they did not measure the flow for each one, I’m not buying it if it has less flow
They’re a direct clone so it’ll have the same flow. What it won’t have is the metered output (i.e. two stage flow) as far as i know.
Ok im buying the clone
Got the graham white instead of the clone. Came in today. Won’t regret
