Bought a k3
Bought a k3 now I don’t know what else I need. I have a shocker series set also what can I reuse off this kit? And what do I need to buy new? I’m upgrading tanks and compressors so I’m good there just need to know everything else I need.
Brass fittings/connections and the appropriate air lines.
You’ll need at a minimum 3/8 inch inside diameter air hoses rated for 300 PSI (it’s a bit of overkill, but it handle the elements better) and then brass fittings/connections for your tank and to the K3.
How are you going to push air to the horns? Manual valve or electric?
Electric for now. I have another question I currently own two compressors a 444c and a 325c I know these are two different compressors one which is a constant duty and the other is not. Will it be ok to run both of these for a month or so until I buy another 444c?
Yup, then run all three.
Make sure you have at least a 5 gallon tank as well.
I have a 8.5 gallon tank showing up tommorow.
