Building my system
I got the P-3s, got Grovers on the way, got a 7 gallon tank with 5 ports. I am not sure if I am going to permanently mount the P-3s. I want a loud horn but not as my everyday horn. So, assuming I mount the Grovers, is a Viair 450C going to be alright? I was going to get a 175 Pop off valve and a 110/150psi switch. I am new at this, so I value your opinions and expertise. I am an occasional tooter, not really into scaring the chili out of anyone (except ocasionally).
Get a 400c and stay with 150 psi. 130 psi is optimal for P horns. P horns are not air hogs like K or M horns.
^ I will second that.
Anyone know what PSI the 24 inch Grovers might use? Like I said, I new at this. If I get a 400C rated at 150 psi, can I still use it for horns rate at 120psi? Or would I have to installed a regulator. Also, can the 400C fill a 7gallon tank okay. I apologize, for these elementary questions and if there is a heading or topic on this site that answers these questions, direct me to it. Thanks guys, I’m learning.
greg
150 should be ok I would think.
