I found a member selling a rebuilt K3HA, and compressor for a good deal so I contacted him and got it on hold.
It comes with:
Nathan Airchime K3HA horns with custom mounts
3 Gallon Air Tank
VIAIR 380C Compressor
165/200 PSI Pressure Switch
12V Relay
…and I beleive he said I’d need to buy some fittings.
I know I’ll be needing a 1/2in. Valve and 1/2in tubing with some power and ground wires.
But when I call HB I’d like to know exactly what I’m askin for.
When you call just say what you already have and they will get you everything you need. The 1/2 valve is like 40-50 and the tubing is 10bucks for 10 feet. So it all depends how much you need.
yeah i called them with this.
i have a K3…
i need a 12gal tank 1/2in everything 200psi to 150psi regulator and everything in between on top of dual 444C’s… bout a minute later i had a price
