You can make individual manifolds. But you cant make a real manifold without the cast they use for casting the K series manifolds. As far as the bells go do you know if any of the bells are cracked or chipped? Are you sure only one diagphram is busted?
175 with no shipping is a decent deal. A new diaphram is $16 from Hornblasters.
I have ideas to make a manifold out of square tubing, but would take some real skills.
Otherwise watch ebay for a real one or do the individual brackets.
What type of tools do you have for fabricating? I do a lot of my own fabricating and can either help with ideas or building custom brackets or manifold.
Making a manifold would be ok if it’s for your ride.
But I don’t see a custom manifold being very good selling point.
On a side note, you can usually sell individual bells on ebay for at least 75 a piece.
If you want to resell them send me a PM with what bells you got and pictures I will buy them. And as far as K horns go I have a few bells laying around dont have any manifolds though other than two high manifolds both with bells on them. Would you rather have a cast manifold if you buy the bells?
It’s easiest to email a couple .PDFs or .JPGs.
If you throw your email up, I’ll edit your post to remove it right away.
Then I’ll make a couple drawings at work tomorrow.
What size square tubing do you have?
Can you tap 3/8-16 holes or would you rather weld studs? (threaded rod)
