I have a conductos kit from Hormblasters. with 4 horns
I have dual compressors with a 5 gal tank.
if i had more horns do i need a bigger tank ? what else will i need?
Sure you can.  It would reduce your honk time a little.
You have enough compressor to add another 5 gallons if you wanted.
You would need to add another airline for the additional horn.
If you’ve been bitten by the horn bug, you might want to start looking at real trainhorns. Get it over with…lol
Welcome.
^^ Ditto.
You might just want to sell the Conductor horns once you’ve gotten ahold of a K3.
Ya, and watch out for that horn bug, I caught it a year ago and seemed to have “invested” (lol) over 3K into my system.
I agree with the bug,
I would luv a real set of horns but, wanna keep everything hidden.
I have onboard air  to power my front and rear bags also.
My horns are behind my grille you dont even know they are there. was gonna add another set of horns underneath the truck, 2 at each side.
What kind of truck do you have?
There’s a guy on here (maybe more) with a K3 behind the grill of his Silverado.
You can take the bells off the manifold & mount them separately.
There are quite a few guys with K3LA’s mounted behind their front grills or behind their bumpers. Check out the truck installs section on HB.
Kris
http://www.hornblasters.com/installs/set/?jerrys06silverado
I’m of of them…
You can have as many horn sets on your setup as you want… I have the k3la in my grill and i have the shockers mounted on the frame hooked up to my alarm.
I vote for the upgrade to airchimes!
