Hey guys i’m kinda stuck on installing my new K5la’s. Everything is finally mounted as far as the compressors,tank,Air-line ran,and the k5las mounted i’m just confused about the wireing. I want to put my compressors on a toggle so i can turn them on/off when needed but also have them on a pressure switch to my ignition. Now i heard there is a certain way to wire this or it could damage the compressors? Then I wanted my valve to be wired to a toggle as well to switch from stock to train horn.
thanks in advance guys i’m gettin excited to hear these things i’ve had them for almost a month now and finally have the time for the install
my setup is
Nathan K5LA
5/8" air-line
(2) Viair 380c compressors
8.5 gallon tank
