awsome install!you can tell you put lots of time into it! great job!
Hey, Great instal, Saw you out at 5A the other weekend.
I got them from SkyCraft (local electronics surplus store)
I used the same fans on the outside of the mailbox on my previous setup and they held up fine, even through a heavy rainstorms and blizzards.
also how did you plumb the airline from the k3 to the tanks?
Here’s a shot of the bottom of the rack before I sealed it with epoxy and shot it with bedliner.
The noid is plumbed off of an elbow on the 2nd tank and has a straight shot to another elbow on the bottom port of the manifold.
5A?
Sure it was me?
I’ve been in NYC for the past 2 weeks
I know that this is an old thread but I need some help from you!
This is my car
I wanted to have my Shocker horns installed under the roof basket. I was thinking of running a toolbox on the roof like you have but how do you get the power wire from the car to the roof?
I used Heyco water tight wiring plugs
1 positive cable, 1 negative cable and 1 multi-wire conduit cable for relay triggers.
I’ve actually used these same plugs between stringers on boats and I have yet to see one leak through
Where’s the info on the lens cap? hahaha
I’d sure like to see the inside cab setup with all the switches you have.
Sorry, I meant to direct my reply to Snake Eater and his roof mounted tool box horns. Yeah, sure would like to see what the control station looks like!
