Check Valves to use
Good evening fellow Blasters, I just updated my system to a 485 dual compressor system, I knew the Viair check valves leaker so I purchased two SMC check valves, received them Friday, installed yesterday, 200 lbs system empty at quoting time today, check all other connections no leaks, what check valve is worth buying to hold the pressure
