Chill out my shockers
I must be getting old…
My pressure switch is set to turn off at 125. My horns are unregulated and honk at 125. DANG THEY ARE LOUD!!! I would like to quite them down some. I like the sound just need to quiet them some. would putting a regulator to reduce the pressure quiet them down at all?
^ yes, that would work. as well as if you ran smaller diameter hose to the horns.
The easiest way, and also easily removable, would be to make a bottle-neck with a few fittings.
Zip-tie a couple socks on each one?
Lool
