Cleaning horns
What is the best way or best thing to use to clean a set of k5’s.
If they have alot of rr paint on them you need to soak them in aircraft paint removal overnight. Unless it’s thin paint then just paint stripper in a spray can will work
I have black. Powder coated k5 how often should i clean them? Do i have to remove them for cleaning? Whats the easiest way to. Clean them
Unless you want to take the paint off, just clean them the same way you’d clean your car. Powdercoat is a nice finish - I’d just use detergent & water. If you get water inside, just give them a good blast afterwards.
Thanks buddy
