I have the dual 400c viair compressors. Should I “Y” theses compressors together and then run one air hose to the tank using one tank inlet or run individual air hose to each compressor and use 2 tank inlets?
You can join them. I use a T fitting on the tank to give me the two ports needed for the twins.
