Compressor issue
Hi folks,
I am installing a shocker 240 kit in a truck.
The install is done except for the switches.
I was testing everything out before drilling the dash holes and ran into an issue.
The compressor switches on no problem. The tank won’t build any pressure though. The compressor is a Viair 400c with an inline check valve that came installed from the factory.
I removed the line going into the tank while the compressor was running and no air is coming out of it.
I remove the intake filter and it seems like the air is blowing in and out of the intake.
This is not the first set of horns and air set-up I have installed, so I am a little familiar with it but I have not run into this before.
I know the air will take the route of least resistance. Is there something wrong with the check valve, or the intake valve?
Where should I start looking?
Chris
check valve on backwards?
is this compressor new or is it older / used/ maybe checkvalve is bad / seized up… take lead line off compressr and see if air comes out.
Brand new compressor.
Check valve is facing the right way according to the air flow direction arrow
