Compressor on...tank not filling
My compressor is coming on but my tank is not filling with air.
Anyone know what the problem could be? Setup is about 2 months old.
Thanks,
there is a leak somewhere in your air system or the reed valve on top of the compressor piston is broken (Happened to me). Disconnect the compressor from the tank and turn it on and see if it blows any air. If it does, then you have a big leak somewhere. If it doesnt then your compressor is broken.
ok…I disconnected the compressor from the tank, turned compressor on and it is running but no air is coming out. Is this reed valve something that is replaceable by me or do I need a new compressor?
Thanks,
What compressor is it? I took my viair apart and replaced it without problems, but you can send it back for them to repair if you want.
