can i run my compressor while i wait a week for my new pressure switch?
I do you have a gauge to watch your pressure? If you do you can do it carefully. but don’t forget about it. When a tank exploads its three times the pressure when it goes. Just becareful and have a toggle switch in line to turn off.
Good Luck,
John
What he said… just be careful not to exceed rated pressure.
For a week, running the compressor for only a few minutes at a time - you should be fine. If the safety valve bleeds off - you got greedy…
No worries - the safety valve will re-set below its bleed-off pressure.
