Compressor Toggle question....
Alright real quick, I have my compressor already connected to my ingnition which works fine. However, there are already times when I want to manually turn the compressor off…I am going to use the toggle switch that came from my HornAir 540 kit from HornBlasters…heres my question:
Do I need to put a fuse between the switch and where my connector is on my ignition? I already used both fuse connectors that came with my kit for the pressure swtich and my button to release the air.
Thanks
I like to put the fuse as close to the positive source as reasonably possible…that means before any switches or components.
so put a fuse close to where i connected to my ignition wire?
Yes, that is the safest.
Then if there’s ever a short anywhere along the wire run, it’s protected.
awesome, thanks so much ear!
