compressor
the compressor is getting voltage but is not turning on is there anything that could cause it not to turn on
check ground…
x2 check your ground. Check your battery connections. Is the system is already pressurized? Maybe it’s a bad pressure switch.
connect direct power to your compressor leads. if the compressor comes on its not your compressor. check your grounds, relay and pressure switch.
