Was wondering about a picture I saw on the Viair website. Who makes the 90 degree elbows that connect the 2 tanks together can’t seem to locate by doing a web search any help would be really appreciated.
Welcome to the forum. You can fabricate a connection like that using street elbows and a hose with one end that swivels. It might also be possible with air brake tubing and instant tube fittings.
Like Dan said you can hard plumb it or use 90 degree PTC fittings w/ DOT tubing.
The ones in the picture are aluminum AN fittings with ss braided hose usually used on cars. The fittings are reusable and attach with a nut. Some brands to look for are Aeroquip, Earls, Russell. Summit and Jegs are a couple big suppliers.
The same industrial fittings are called JIC and are usually crimped onto the hose.
Those fittings are all Russell I believe.
The vehicle is owned by ARC Audio and is a UTV that they use at events.
Russell Performance
http://www.russellperformance.com/
