ive bought the 175psi kit,the pressure switch is 175psi shut off but the safety valve is also 175psi opening?(sais 175psi on it) so before the pressure switch turns the pump off my air blasts out the tank…
(or probably a few seconds before)the pressure switch kicks in…
should i of been supplied with a 200psi safety valve? that makes more sense and will allow the switch to turn the pump off at 175 before it blows the plunger out?
Give hornblasters a call… I’m sure they will get this taken care of for you
I can mail you a 235psi safety valve cheaper than hornblasters sells it lol. bought one when I didnt need it. Fail on my part
yeah they send you the wrong one give hornblasters a call or talk to twist and see if he send you the one he has… try not to run ur air system without a safety valve u never know when the pressure switch is going to fail
been told i need a 235psi one?? what about a 200psi safety valve ? wouldnt that be enough? why 235? just wondered thats all…
I apologize about the error in your kit. We’ll have it resolved as soon as possible!
its cool…
thanks for fast response and sorting it out…
hornblasters have one of the best customer service ever so don’t worry about it they will fix everything for u fast!!
