So, lets say one wanted to replace a broken/well used horn from the 228VX kit…or upgrade an already existing kit (from hornblasters of course) with one of the horns from the 228 kit…
are you able to order a single horn, with or without the fittings…or is that a no-go?
…UGH, see…the problem I’m running into is having enough room to add another one.
I would like to get the 16.75" one but I’m pretty sure it wont fit, and the LAST thing I want to do it tear everything apart and reroute all the lines…AGAIN X_X lol
See that’s what I’m afraid of…i’m not sure if it will or not!
I was looking around at the push-in fitting the air lines are connected to and for the life of me I can’t find a male threaded 1/2" to 3-way split push fitting that’s like the male 1/2" to 2-way split that came with the kit.
I would have to use the stock 2-way split that came with the kit, and off one of the reduced 5/16ths lines (I think that’s the size) I would need to run another “T” push/in splitter to hook up the other horn…
and by doing that, I know it’ll blow air through it…but I’m not sure if it’ll sound right.
If you can post a pic of the horns you want to combine on www.hornwhistleboard.com, those guys should know. Be aware, they are not into scaring people.
