I have the air zeneth PG. I was wondering if the sensor piece that goes on the tank HAS to be mounted on the top of the tank, or i can mount it into 1 of the 4 holes in the front of the tank? I have the 8.5 gallon 8 port tank
My install has consisted of 5 nights 48 cans of coors and 2 of those nights passing out in the back of my truck. I can’t wait till this is done…its getting cold out.
Yes it can be mounted almost anywhere - any direction.
Like MarineOne said - just don’t use the bottom of the tank.
Water collects there and would plug the sensor. Your drain fitting should be there anyway.
So i got everything mounted. I started to freak out when the guage hit 200psi and it didnt turn off…so i let it run and it final turned off 215psi. I didnt think that was normal for it to be 15psi off. I figured it would be off a couple either way. But im gald it turned off. Has anyone ran into this?
