Looking for a small kit, that packs a loud punch, but is small enough to fit in a dodge viper.
Any recommendations?
I can give you the measurements for the black shocker horns so you can see if they will fit. The horns would be SICK on a dodge viper. Here are the measurements:
Part Number: AH-S4
Material: High-Impact ABS
Length: 12.75”, 14.75”, 16.25”, 19.5”
Flare: 5”
Weight (All Four): 4.5lbs
Fitting Size: 1/8” NPT (M)
And you can probably mount the tank and compressor in the trunk. What do you think man?
Thanks for the measurments… I’ll have to see where I can put the horns… if I decide to do this.
The compressor though, looks big. Do you have the mesurments for the small guy they have listed here?
http://www.hornblasters.com/products/details.php?item=HK-S4-V127
Ya man here are the measurements for EVERYTHING in the kit. They are under the “Specifications” tab on the product’s page. Just for future reference.
Part Number: HK-S4-V127
Horn: Black Finish Four Horns
Flare: 5”
Air Source Kit: Viair 20003
Working Pressure: 120 PSI
Length: 15.0”
Width: 6.0”
Height: 13.0”
Net Weight: 13.75 lbs
Air Source Kit Tank: Viair 1.5 Gallon 4 Port Tank
Volume: 1.5 Gallons/6.6 Liters
1/4" NPT Ports: 4
Length: 15”
Width: 6”
Height: 8.5”
Weight: 8.65 lbs
Air Source Kit Compressor: Viair 275 Air Compressor
Voltage: 12 Volts
Max Amperage: 18 amps
Maximum Duty Cycle: 25 % @ 100 PSI
Maximum Working Pressure: 150 PSI
Length: 6.5”
Width: 3.5”
Height: 4.5”
Weight: 5.1 lbs
