Does anyone know??
i was wondering the distance between the hole’s on the mount of the k3la’s manifold. not sure if that came out right lol. the (mounting bracket) thanks.
i might have the perfect spot to mount them
ware are you
mounting them
at whats your ride
i have a 2005 ford explorer i took the spare tire out and the hoist mechanism for it< cleared up plenty room. there are to bolts on one side of the hoist that are right next to eachother and i think if the distance is correct that would be the perfect spot for them
The distance is 1.5 inches from center or 3 inches diagonally
thats from screw hole to screw hole correct? and wouldnt be able to mount them diagnally the bolt holes are next to eachother.
could i always drill the holes a little bigger on the manifold mount?
Are those holes not large enough ?  4 half inch bolts fit these holes.
no no there long enough, i just wanted to know how far apart they were spaced
As I stated 3 inches diagonally X
anyone know if home depot or menards or lowes has thick steel, that doesnt bend, i might just have someone weld that to each end of the frame.
ya sorry about that had a brain fart thanks alot.
[QUOTE=xlt85;37941]anyone know if home depot or menards or lowes has thick steel, that doesnt bend, i might just have someone weld that to each end of the frame.[/QUOTE
Go to A metal supply house or fabrication shop, like someone who builds race cars and see if they have what you want. 3/16 to 1/4 inch steel is plenty strong for mounting the k3s…
nice will do and thank you very much.
Anytime,and good luck.
i own a 1985 ford
f250 if you take a
good look at my
sighature pic you
can see how mine
are mounted but
how eaver i have
S4 SHOCKERS so
i agree with what
jetman is saying
nice kinda hard for me to see but i think im just going to go with the steel welded to each side of the frame thanks alot though this site has proven again to be very helpful.
buy the way
i will be owning
a K3 sum time
so i have alot of room you see
i got lucky my spare
tire mount can no
longer be usd
spare tire is in my
bed plus thar wuss
a cross beam that
had holes all ready
in it so my install
wuss a breez plus
my the mounting
bracket i put my
horns on i got from
my work.
sweet you cant beat that. ya mines a little newer so having to remove things lol. but doesnt matter nothing will stop me from mounting these k3"s
try it out man
the best tip
i can give a is
try what works
and what dosent
but what you just
sed probly wudd be
the best way to go
hell try it hope it all
works out for ya man.ps love your
avatar pic.pease
