It’s on Facebook so, naturally, You’d need an account to view it. Uploading on Photobucket and changing the link if it works. The video is near the file size limit
I don’t think that is a good idea. It is pretty noisy already with all those a-holes honking for no particular reason and then imagine all of them using train horns. Small and annoying things like honking in a traffic jam like it will magically disappear when they honk. Or the moment the light turns green some idiot honks his horn behind you.
You must be banished from this community. The hornblasters bible clearly states that one must honk their horn(s) ANY TIME they see a great hornblasting opportunity or have due cause to do so under the highway code.
Guards!! Take this traitor away and off with his head!!
When I said " I use mine only when the situation calls for it."
It meant any opportunity to use the train horns. Even when that certain situation only requires the use of the stock horn. Except when coming home, since we know what could happen there.
