Keep fixing it till its broken.
Exactly, if it aint broke, why fix it?
kinda off topicā¦
but i have the dual 480cc, and theyāre great i must say. but is there a 145/175 pressure switch available for them?
i was lookn at this one off the site: http://www.hornblasters.com/products/details.php?i=145-175-psi-american-pressure-swtich
but i dunno if it would workā¦
i have this one right now: http://www.hornblasters.com/products/details.php?i=viair-110-145-pressure-switch
That pressure switch will work with the 480ās.
dual�
otherwise travis has been informing me about using regulators⦠sounds interesting
Regulator is for air flow out to the horns, pressure switch is to turn the compressors on and off.
1 pressure switch, 2 relays. Not to be confused with 2 girls 1 cup.
Any pressure switch will work on 480ās since they are 200 psi compressorās.
Wiring schematic.
http://www.viaircorp.com/OnRoad/Schematics/dualc_wd.pdf
All you need to do is replace the switch you have now with the 175 psi one.
The benefit of a regulator is that you store air in the tank at 200 psi but limit the pressure to the horns. This means that you go longer between tank fills. The downside is that it is harder on the compressors to have to fill to 200 psi. I run dual 480cās too and I am careful not to run them much on really hot days.
I beat my 480ās. They never get a break. If Im gonna sell them I wanna beat a few to see how they really last. I have a 480 that runs about 5 hours a day at 15 volts. 175 to 200 psi. Inside a room in my house. No ventilation. It runs my powder coating business with a 5 gallon tank. Been going good for a year now.
Mine are inside my toolbox on my truck with no ventilation. They havenāt run 5 hours total since I got them.
LOL⦠my dual 400cās havenāt seen 5 hours yet eitherā¦
Where do you have the speaker for your PA installed?
Under the passanger floor boardā¦
Did you know that those little horn speakers will fit inside the fender vents on our trucks?
These compressors are built to take the abuse, to what extent I will find out.
