dual 480c compressor/relay problem
So today i found out one of my compressors was not running.
so i started the process of elimination. i was able to determine that it is not a compressor issue. i switched the wiring around in the relays so that the compressor that was not working before was, and visa versa for the other
one.
as i kept working i checked all the positives and grounds, and switched source. that’s when i noticed that only one of the relays clicks when i flip the on switch in the cab. i clearly remember when i was installing it they are both supposed to click. even when i reversed the switched source wire the same relay clicked, but the other didnt.
im not sure whether or no the relay is the problem. but your help would be appreciated.
Are they separate relays or do you have the dual relay / pressure switch?
Did you check the ground on the relay?
I’m a little confused but if the relays were switched then it sounds like one of them is bad.
They are separate relays. Its the dual 480c kit hornblasters sells.
Like Dan said the relay is probably bad if all the connections are good.
