From the compressor back to the battery, or any ground.
Only real trick here is using that switch, linked above. NOT ALL RADIO SHACKS HAVE IT, IF YOU HAVE TIME ORDER ONLINE. I HAD TO VISIT 3 STORES TO FIND IT.
Please do not use a toggle switch with any VIAIR compressor as the sole means to power the pump(s). The switch can burn out if you’re loading it with too much power, you should still use a relay to keep that from happening.
Agreed, ALWAYS use a pressure switch to turn the compressor on and off. Use a relay and a toggle to turn power to the relay off, which cuts power to the compressor using LOW AMP DRAW.
Pressurizing an air tank beyond its rating can end with a catastrophic failure… Especially if the tank is old and has been compromised internally due to rust.
-Aluminum tanks are another item I don’t recommend since they’re not malleable like steel and tend to turn into shrapnel if/when they experience a
failure.
Speaking of relays, does anyone know of a better relay than the ones provided with the viair pump install kits.what I have is a dual pump dual relay set-up and one of the relays from time to time will stick,what happens next is pissing me off badly. smack the relay it behaves itself for a month or better then out of no where it sticks and cuses the 60amp fuse box to overheat to the point that the fuse melts and you have to pry the cover off the block and change the block and fuse both as a new unit. :mad:
What? Thats horrible! What apmerage fuses and wire guage are you using? Something is not right. BTW if a relay is sticking you are probily putting too many amps thru it.
i just hardwired everything of mine and got a pressure guage runnin inbetween my seats so i can see what psi im at,much rather hav it this way than a pressure switch
how they gonna know if you used a pressure switch or regular switch??and because this way i can run w/e psi i want and not worry about getting a new pressure switch
When the compressor is sent in for warranty inspection and the intake valve is completely shot after 3-5 months, and the piston seal is completely worn out - then something is amiss. You can tell if a compressor has been continuously operated past its rated duty cycle.
When seals are blown out because of over pressure operation, that’s not something that is covered by warranty. Its considered abuse.
Its your prerogative to do whatever you want with the compressors, but its up to the company who built them to cover them depending on their condition.
