Hey guys im wanting to install an electric drain kit like the one hornblasts sell. I already have the valve but am stuck on how you wire the valve. Do i ground the valve to the truck on the frame and run a power wire to one side of the switch and the other wire from the valve for it to work properly?
I had an electric drain on my Hilux fitted with K3’s, but what I also done was have a piece of 1/2" pipe of the solenoid I was using to drain and then had it routed pointing out to side of the truck, about knee height off the ground, which I found was sometimes exceptionally funny when pulling up to people waiting at bus stops, first it’s the noise that makes them jump & then followed by a watery mist lol lol :D:D:D:D
