Electric valve solenoid failure?
Has anyone had or ever heard of a electric valve solenoid failing causing the air to activate the horn without notice?:eek:
no… a valve is closed so if it fails it just wont open… if it opens and failes means you wanted to hit the horns in the first place so its just going to empty the tank
http://www.trainhornforums.com/showthread.php?t=2058
check out that thread for some info…
it has and can happen… supposedly unlikely , but i had it happen twice .
x2 check ur ground
