Well since I have ordered my kit just a few questions.
Can I install my dual 480c compressors in my ute cab 1 behind each seat?
Let’s say I have 165-200 psi pressure swich, I have 170 psi left in tanks is there any way I can get compressors to kick in again with out getting psi under 165?
If I need to extend compressor lines to tank do they also need to be braided?
Ok as my car is old and crap I might not always want 2 compressors running what’s the best way to turn just one off?
From my google skills I go from
Single wire to pressure swich > pressure swich out to 2 relays. Relays are hard wired.
Now if I want compressors switched I would need to bring those switched pressure swiches back into cab then back out.
yep cheers for that guys i want to swich both compressors impedantly (still go through pressure swich though as if i just need a trickle of air toping up tyres with engine off its pointless running 2. or if 2 compressors has 2 much drain on my battery when im driving at night and have all my lights on. My car has a n70Zz battery in it but only a 55A altonator.
i might have to ount them in a small box in the tray then. i dont think i have that much room under tray.
once i get them ill give them a quick go in the cab there really isnt alot of options is a small ute
